Well I've decided to build a new pc. My cooling goals are to provide adequate cooling to a q6600 and a 8800gt with a water cooling system. I do not plan on o/c'ing at the moment, but may decide to do so in the future. I would like the system to be as quiet as possible. I also have never built a wc rig and since I work as an IT consultant, I consider it one more skill I need to learn.
I have done some research, and based on my budget, I'm pretty set on these items. Basically I am just hoping someone can look over these proposed items and tell me if there are an glaring mistakes I've made, things I've missed, etc. I am ordering the items from performace-pc, and when you add to cart it asks for fitting sizes you want, so I assume the fittings are in order. I'm going with 3/8 ID tubing throughout, mostly because I dont like the look of 1/2 and even if I do o/c, it will not be to max levels.
Thanks in advance!
Alphacool Laing DDC-Pump 12V Pro Water Tank (comes with pump and top mounted res)
Alphacool NexXxoS HP Pro Socket 775
EK-FC88 GT/GTS (G92) High Performance Water Block
Black Ice Pro II Compact High Performance Radiator - 240
Black Ice Pro Compact High Performance Radiator - 120
Feser One F1 Cooling Fluid - Clear/UV Blue - 1 Liter
Tygon 3603 3/8" ID (1/2" OD) Clear Tubing - 10 ft for trial and error tube running
Nexus 120 mm Real Silent Case Fan (22.8 dB(A), 36.87 CFM)
Thanks in advance!
