Just looking for a little validation, no I don't want a hug...lol...
Hello all I'm new here AND to the world of liquid cooling, so here goes
I am in the process of planning out my next rig
These are the components that I plan to use for a liquid cooled system.
Please help me make the right choices for the cooling system and or any improvements you can add, thanks!
Case: Lian Li PC-V1200B <--may change any suggestions?
System Board: DFI LANPARTY UT NF4 SLI-DR Expert
CPU: AMD Athlon 64x2 4400+
PCI-e/SLi Video: GeForce 7800GTX (single at first)
WATER COOLING SYSTEM:
Thermaltake: Liquid Level/Flow Meter Aquabay M1 (may change any suggestions?)
http://www.thermaltakeusa.com/2005/watercooling/cl-w0032AquaBayM1/cl-w0032.htm
Thermaltake: T-Type Water Temp Indicator (may change any suggestions?)
http://www.thermaltakeusa.com/2005/watercooling/cl-w0033/cl-w0033.htm
DangerDen: Danger Den Fill Port (going to use a T-line system)
http://www.dangerdenstore.com/home.php?cat=35
Radiator:
Thermochill PA120.1 (possibly 2, one mounted at front/bottom of case one at top/rear)
http://thermochill.com/pa1201.php
Or possibly a single PA120.2 (mounted on top of case)
http://thermochill.com/pa1202.php
ALTERNATE Radiators:
MHQ120-S-Combo (Single 120mm Fan/Shroud combo) also possibly 2 of these
http://www.moddershq.com/
any suggestions here?
PUMP:
Danger Den DD12V-D5 Pump
http://www.dangerdenstore.com/product.php?productid=175&cat=4&page=1
Any other suggestions????
Water Blocks:
CPU:
Swiftech Storm
http://www.overcool.com/Exec/product.asp?userid=16224727709383&item_id=35273
Or
Danger Den MAZE4 for A64 and Opteron Motherboards
http://www.dangerdenstore.com/product.php?productid=31&cat=20&page=1
GPU:
Danger Den NV-78
http://www.dangerdenstore.com/product.php?productid=189&cat=48&page=1
(Currently only getting 1, will eventually get the second along with second video card)
Chipset:
Freezer Series for Athlon 64 (SLI) Boards
http://www.techpowerup.com/reviews/Mips/DFIFreezer/
(This is the only one I've found online so far, any others out there? Will I really need one? I do intend to overclock the system once it is completely burned in)
Coolant/Additives:
???NO IDEA???
Or does it really matter?
Anything else on this list that I might have missed? Please feel free to tell me!!! Make your suggestions please! Thanks in advance for the help/suggestions!!!
Radiator:
PUMP:
Water Blocks:
CPU:
Swiftech Storm
Or
GPU:
Danger Den NV-78
Chipset:
Coolant/Additives:
???NO IDEA???
