Another new build evaluation.
jstenuf
I need some constructive input on the new rig listed below. In addition, I used one of the on line PSU wattage calculators and It recommended an 850 PSU:eek: for what I have listed below. I find this difficult to believe so any recommendations on how much wattage I will need will be appreciated. .
MB - EVGA 680i A1 Motherboard
HSF - Thermalright Ulta 120 Heat Sink
Scythe S Flex 1600rpm, 63.7 CFM
Arctic Cool MX1-1 Thermal Paste
CPU - Intel Q6700 Overclocked
GPU – 2 BFG Geforce 8800 GTX OC2 -SLI
MEMORY – Corsair 2x2048 6400c4 or 8500 c5
PSU?
Optical Drive - Lite On 20X LH-20 A1S SATA
HD - Wester Digital Raptor 150GB
Western Digital Caviar 500 GB 16 MB
Monitor – 30 inch Dell HC
Sound Card - Creative Xfi Fatal1ty Pro
CASE – CM Stacker Evo existing
Speakers - Logitech Z5500 existing
With your setup an 850 Watt PSU is a most reasonable recommendation. Check out the Silverstone Zeus 850 Watt model. It's an excellent PSU, and I have one for a similar rig. No problems and no worries about future upgrades.
The Enermax Galaxy 1000W unit is also popular, and the new Silverstone Olympia 1000W is also worth a look.
As for the rest of the build, everything looks good. That'll be one sick machine. One piece of advice is to buy the PC-6400 RAM, as quad cores don't overclock to a range where having PC-8500 RAM would be useful. Getting it would be wasting money for RAM with looser (c5) timings.
Good luck,
Mark.
I agree......look at the Ultra 1000W review on [H] enthusiast or JonnyGuru.
For SLI'd 8800GTX you are gonna need 4 PCI-e connectors, so a really new PSU is going to be very helpful......
that Ultra model is especially sweet due to the modular design, relatively small size, and great price point.
You need power. Look at the 1000W models especially, there arent many.
Its the quad core CPU and dual GTX's that are power hungry. Most of the power needed will be from the +12v rails. Still, I doubt it will use 80% of an 850W PSU.
