Just games; turn on play games; turn off so lots of power cycle
No limit but thought was ~$1000
3) Where do you live?
Mass
cpu, case, psu, drives, mb, memory
None (maybe pull the xfi sound card; not sure of exact model but it is the 'good' one).
6) Will you be overclocking?
none
currently 22; but want to support dell 27 (high resolution)
Next 2-3 months
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Quality on board sound would be nice; ethernet, crossfire
Have access to legal (for personal home usage) wiindows 7 32/64 (plan is 64)
back ground
I currently have a e8400/8800gts g92 xp system which I use to play games (turn on when playing otherwise it is off; so it gets a fair number of power cycles; I use a linux system for web and stuff and that system stays on 24x7).
plan/objective:
My thought was to build a new system (running windows 7 64) and I figure the new system would accomplish 2 tasks; 2 to 4x faster and upgrade to windows 7.
The system I've been spec'ing (nothing purchased):
asrock extreme 4 p67 mb ~$152
2500K intel cpu ~$190
seagate constellation st3500514 500GB ~$90
g.skill ripjaws F3-12800CL7D-4GBRM (7-8-7-24) $65
intel x25-M 120GB g2 ~$220
lian 9f $128
seasonic x 650 ~$120
windows 7
ati 6950 (initially one but might upgrade two 2 hence 650W psu)
dvd drive ~15
blu-ray drive ~$50
Any comments or suggestion on changes or does it look perfect Bit more than I want to spend - maybe drop the ssd ?
Mass
none
Next 2-3 months
back ground
plan/objective:
lian 9f $128
windows 7
dvd drive ~15
blu-ray drive ~$50
