Relentless702
- Jan 2, 2009
Mobo - GA-EP43 http://www.newegg.com/Product/Product.aspx?Item=N82E16813128347&Tpk=ga-ep43-ds3l
Proc - Q6600 @ stock
RAM - G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 800 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
Everything is stock, bios settings are default. Overall the PC seems to be running fine. Have been running multiple tests to stress the CPU (Prime95, Intel Burn Test, Sandra, etc.) and so far no issues and comfortabe temps. Haven't even installed any games yet.
Last night I decided to run Memtest with both RAM modules in dual channel. Ran two passes with no errors, but on the fourth test of the third pass I had one error. I know many people say to run at least 7+ passes, but I also read alot of people saying one error is too many.
Today after work I ran two passes on each RAM stick individually with no errors. Ran them in dual channel once again, and recieved the same error on the third pass, fourth test.
The RAM specs say to run them at 1.8-1.9v. My mobo is on auto and has them at 1.8v. Of course, first and foremost I want to make sure I have no faulty hardware and that my system is stable before moving forward. I have been doing alot of research but the information leads to a thousand different directions. I know this must be beating a dead horse for most of you, but any advice on this would be greatly appreciated.
