Another LP2475w? Or something else?
I've had an LP2475w for a little over a year now, and think it's time to get another IPS. Common sense led me to think another LP2475w would be a good choice, but should I consider anything else? I'm not against buying used, and I think $500 is about the most I'd be willing to spend.
I'd like to be at least 1920x1200, and whatever I get, I want the coloring to be pretty consistent (or at least adjustable) to the LP2475w. At least I think I do? Hard to say :D. Input lag isn't an issue for me.
Well to make everything look the same colorwise, I would stick with another the LP2475w. if you want to try something else, look at:
Dell U2410
HP ZR24W
