I've already picked out most parts, but I'd like advice on wether these are worth the money and what power supply and dvd burner to get.
Some gaming, nothing fancy, Portal 2, Darkspore (little brother), possibly some other games. Web browsing and lots of word processing.
$500-$600, yes
3) Where do you live?
New York City
RAM, CPU, Motherboard, Power supply, graphics card, hard drive, dvd burner. I can probably get a monitor, but I'm not sure. (everything except a case)
Case, I need to check the make and model, it's at a friends house.
6) Will you be overclocking?
no
18" to 21"
At the absolute earliest June, at the latest September.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Nothing special, VGA USB 2.0, etc
No, but I have connections and might be able to get one. I am planning on using windows 7 home premium.
$99 - AMD Phenom II X4 840 + Biostar A780L3G AM3 760G mATX Motherboard bundle deal
http://www.microcenter.com/specials/promotions/AMDbundlePROMO.html
$59 - CORSAIR Vengeance 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 Desktop Memory Model CMZ4GX3M2A1600C8
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145348
$159 - IceQ X Turbo H679QNT1G2M Radeon HD 6790 1GB 256-bit
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161371
$61 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
http://www.amazon.com/Samsung-Spinp...1?s=electronics&ie=UTF8&qid=1301946920&sr=1-1
$500-$600, yes
New York City
no
18" to 21"
