Originally posted by Shinare
You should probably continue the top all the way out to the plexi so that it has some support on that side insted of sagging in like that.
Originally posted by Techx
nice job, but i think it would be cooler to have some uniformity in the colored legos.. for instance to have red trim around the edges and white on the rest of the front pieces. etc
Originally posted by ewarz
its pretty expensive to buy specific colored legos in bulk.
Originally posted by jwill
cool scene inside. just needs some wire organization.
Originally posted by matoch
What do you consider expensive? You can get 50 2x4 blocks for 7 bucks from Lego.com
