Another HS&F ?
EZtarget
I did search before I posted but couldn't find the exact combo. Will a Zalman CNPS8700 LED Fit an Asus P5K-VM in a TT Lanbox.
http://sharkacomputers.com/zacnled3.html
If not what HS&F do you guys recomend with my setup? I'm not a huge overclocker but may want to later on. I will be using a E6320-E6600 CPU. ( haven't bought one yet but looking:rolleyes: ) Thanks for your time.....EZ
It'll fit. How tall was it? 67mm? You'll have some space over it to draw air in.
Otherwise, you can get a XP120, and have the fan blow upwards into the PSU.
(And by E6600, you meant E6750, right?)
Don't buy an E6600 unless it's a really good deal (less than $150.). The E6750 would be a much better value.
The XP-120 will fit in a Lanbox.
Thanks for the advice! Anyone have an E6750 for sale??? EZ
