Another "help me pick a case please" thread
Gigolo
I'm gonna be getting a new case soon and I have it down between the CoolerMaster Praetorian or the Lian Li 6075B
here are the pics in case you don't know which ones.
Lian Li
and
CoolerMaster
Doea anyone have one of these cases? I have found a little info on the CoolerMaster but I can't find any info on the Lian Li. By looking at the pics IMHO the CoolerMaster seems like a nicer build but the Lian Li looks like it would have better air flow. I'm kinda leaning towards the CoolerMaster but any more info I would appreciate.
Thanks,
Matt
both cases are ok, lian li and coolmaster make good cases. i guess it depends do u want a side window ?
Well I can get a window in the CoolerMaster is I want but it just seems weird that I have heard nothing and can't find any info on that Lian Li model. Heck I can't even find someone who even has it.
Well thats pretty much the same case except silver. How do the 2 front fans work? The top blowhole looks like its just got some plain screws in it?
I'm not sure what you're asking. The front grill unscrews with 4 small screws, then you have access to the 2 front fans.. not sure about the top fan, i havent needed to remove it.
I replaced the 2 front fans, with 2 coolermaster blue led fans. Looks pretty damn cool through the front grill.
I'm sorry I really shouldn't post when I'm at work ;) I meant to ask if the fans were easy to swap and it sounds like they are. I remember reading on a different CoolerMaster case and they said that the screws in the top blowhole were ugly and looked kinda out of place(cheap) compared to the rest of the case, what would be your opinion on that?
thanks,
Matt
damn, i should have looked lastnight. From memory I think they are flat on the outside or look more like rivets, maybe the fan unscres from the inside.
