orangezero
- Jan 4, 2003
Hello,
My friend's seagate 7200.7 80gb sata is no longer working. It took forever for the dell to recognize it in the bios, and wouldn't load windows at all. Sometimes it wouldn't recognize it at all. He had used the included utility and it came back an "error 7" or something similar, which basically means a hard drive hardware issue/failure.
So, I took it out, put it in my machine and tried to use some data recovery (same old story, he had 3yrs of pictures, all his itunes, no copies in other locations.....). I used two different data recovery programs. Both worked for a bit, but then BSOD my computer. I'm at the point now where I've found a few more programs to try to get something from it before it completely dies on me. But, I can usually get my motherboard to recognize the drive. When it does, I haven't been able to get into windows at all now.
I'm wondering if I should wipe the MBR? Would that help in this situation at all? I thought basically what I needed to do was get a program that would find the bad sectors and force it to ignore those areas.
I have the ultimate boot cd. Some of the hard disk utilities on there cause an error message as well, but I am able to load them. There are some that can overwrite the MBR and thought it may be worth a shot before I give up.
any ideas?? Like I said, it still is recognized by both computers, most of the time. But now won't load into windows...
thanks for any help or insight.
