Another gaming build @ $800
Shrane
Budget? $800. Cheaper is better. If something is just a bit over my budget but provides noticeable performance gains, then we can add it.
Which parts you need within that budget? CPU, RAM, GPU, MB, Disk Drive, Hard Drive, PSU
What the system is going to be used for? Gaming @ 1920x1200 and general multimedia use.
All of the components that you already have and/or are planning on reusing? I have a full tower case ready to go.
Which components you are considering getting I'm thinking AMD phenom II X2 or X4 based system.
Will you be overclocking? No, but having that ability available would be nice.
When do you plan on building/buying the PC? ASAP
Where do you live? US, Washington State
So- new rig. Again. This will be the last time for awhile. Before I hit the Egg, thought I should get opinions here first. Doing my best to find the absolute best performance for my money. Crossfire is something I MIGHT try in the future, so a board that supports x16 in crossfire would be great, but not critical. I'm thinking the core will be a AMD X2/X4 coupled with a 4890 or 4870. Cheap DDR2 perhaps an antec or corsair PSU. Not a fan of modular PSUs. Am I on the right track so far?
Shiro's build looks good.
... Not a fan of modular PSUs. Am I on the right track so far?
... I'm just curious as to why? :p :confused:
This is my version on your budget. The cooler i suggested isn't one of the normal ones suggested around here however it recieved good marks in a review over at Toms.
$291.98 - GIGABYTE GV-R489-1GH-B Radeon HD 4890 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
GIGABYTE GA-MA790X-UD4P AM3/AM2+/AM2 AMD 790X ATX AMD Motherboard - Retail
$29.99 - Rosewill FORT120 120mm Direct Touch CPU Cooler w/ 775&1366 Retention Brackets - Retail
$199.99 - AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor Model HDZ955FBGIBOX - Retail
$54.99 - G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK - Retail
$99.99 - CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 ... - Retail
$74.99 - Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
$24.99 - LG DVD Burner Black SATA Model GH22NS50 - OEM
Subtotal - $776.92
Shipping to 98103(googled a random washington zip code) - $11.15
Total Shipped - $788.07
There a $20 mail in on the PSU
