PointandClick
- Dec 6, 2008
Finally picked up a dual 1.8 G5 a few months ago. Started tearing it down over the holidays (PITA btw). Finally started the chopping over the last week or two.
I've never liked how most of the mods you see chop everything up or cover the whole back with a big slab of aluminum that doesn't match the case at all.
My plan was to cut out the area of the rear exhaust fans and move them over just enough to make room for the i/o plate and use a banding all the way around to splice the piece back in. I will experiment with anodizing it but if all else fails the sanded aluminum actually matched the original case fairly well.
I picked up a 16" x 16" or so piece of aluminum about the same thickness as the original case from a metal fab place and used the area cut out around the fans as a template to make some guides.
I used a 7/64 bit which is a little small. 1/8 was too big. Because it didn't fit the original holes snug they got off somewhat.
Panel so far.
Put together. Like I said the holes got off, but they line up well enough to bolt together for the most part. the top left is too far off and the bottom is crooked.
Original screw for the fan grill and a couple others I picked up. I'm not happy with either of them. The heads are too big and I don't think I can countersink them enough and maintain enough material between the adjacent holes. Anyone know where I can pick up some with small heads similar to the original?
I have a 3mm drill bit ordered that will hopefully be a better fit. I may go down to the Fastenal dealer and see if they can tell me what size I need too. With a bit closer to the right size I'm confident I can get it to line up pretty slick. The next attempt should go quickly since the cutting is done and I have a template for exactly the number of holes I need.
The motherboard lines up darn near perfectly using the original standoffs so I will just JB Weld them on unless anyone has a different recommendation. I have a mATX board which fits just right without cutting the upper divider where the hdd sits.
Comments and questions are welcome.
Panel so far.
