Another "Choose my mobo" thread!
Doubl3KiLL
More of a I want your opinion thread. So Im looking to build myself a new rig, and Ive been out of the loop for some time now.
Im not going to buy it all in one swoop, so Ive decided to get the momboard first. Im looking for something that will prepar me in all respects to play Quake 4 in "Ultra High". (which requires 500Mb of texture memory, and as the game says "is not recommended")
So I was thinking Im gonna have to go after something with Sli or crossfire. Like I say Ive been out for some time, dont know much about which has been going better performance wise.
Id like to stick with AMD.
Im hopeing to stay around 200 for the motherboard +/- around 50.
Thanks for any insight!
The new ASUS dual x16 sli board. I forgot the model number, but you should know what I'm talking about. Alternately the DFI expert.
I'm pretty sure the mobo he's talking about is the ASUS A8N32-SLI Deluxe. I've heard some pretty good things about that mobo, but the DFI Expert seems to be just about the best board DFI has come out with so far.
I think hes refering to the ASUS A8N-SLI Premium. If not he should be :D
This thing looks like it has all the options I want in a motherboard, and the fact that it is $163 is a big plus. Im researching the DFI board right now also, but the ASUS seems to be coming out on top.
The ASUS A8N32-SLI Deluxe was what he was refering to, but the A8N-SLI Premium is also a very good (and one of the original nforce4) boards out now. Personally, I dont like the selection of where the PCI slots are (scrunched between 2 SLI slots) on the A8N32-SLI. The DFI expert is awesome besides you cant eally be a nUb to the whole overclocking scene or you wont be able to figure out what is what. Also, it requires top end hardware and cheap stuff usually dosent work at all in it.
Asus is known for stability, and good all around boards. You wont be making a bad choice.
Right, which is what I want from a motherboard. Ive owned and ASUS board before, A8NX or something like that, nForce 2, and I loved that thing to death, it was a rock solid motherboard.
See my current sig for specs. I've made the chage from a long time Abit fan. Very impressed with this motherboard. Would absolutly recommend it. Make sure you get a clean PSU as well for stable overclocking. Again, the OCZ 520, or 600w Powerstream SLI is a great choice.
Good luck!
I was referring to the ASUS A8N32-SLI Deluxe. If you don't want to get a dual x16board I recommend the DFI expert, which is better the A8N SLI Deluxe, or the DFI nf4 SLI-DR.
The 8 phase CPU power on the '32 will help you overclock your processor a little bit more successfully.
The asus A8n32 would be a good solid choice. If your looking for max overclock the DFI is the choice but you do need very good knowledge of overclocking and memory timings. If not the board can eat ya up. ASUS is good choice for most folks.
