Another "Check It" before I "Check Out"
se1zure
Please excuse the lame title,, :).
I was wandering if you guys could look over my cart before I hit the checkout button.
Please note, I want to have the option of getting a core2quad later, and I also want to overclock to around 3.4ghz on stock cooling. (so teh e6600 is my choice)
($311)Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 Processor Model BX80557E6600 - Retail
http://www.newegg.com/product/Product.asp?item=N82E16819115003
w/ FREE Ghost Recon Advanced Warfighter :D
($115)GIGABYTE GA-965P-S3 Socket T (LGA 775) Intel P965 Express ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16813128017
($240)CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400 - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16820145590
($74)Seagate Barracuda 7200.10 (Perpendicular Recording) ST3250620AS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.asp?item=N82E16822148144
($49)XCLIO GOODPOWER 500W ATX 500W Power Supply - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16817189005
($49)COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel, SECC ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16811119068
($160)eVGA 256-P2-N624-AR GeForce 7900GS 256MB GDDR3 PCI Express x16 KO Video Card - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16814130056
($5) Arctic Silver 5 Thermal Compound - OEM
Total comes to ~$996 w/ free shippping :).
( Ineed a ddvd drive, but they are out of stock on the one I want, so tis this isn't included.)
Feel free to correct any of my mistakes, or reccoomend different hardware that may be cheaper/better.
Oh, and this is the first computer I have ever build. Will the motherboard come with cables ands stuff like ide for the hd's, or will I need to buy them. Also, what about thermal grease, is that important?
How'd you get free shipping?
Looks pretty good. Personally I'd opt for a better video card if you plan on using it as a gaming rig.
Not familiar with that PSU, but as long as you check the "buy/don't buy" list in the PSU forum you're golden.
i'm not sure how I got free shipping, it just says Shipping : $0.00, maybe cuz my cart is like $900, lolz.
Are you sure the 7900gs can't handle all of todays games at a good ate (i don't need 90fps, just around 40-60 fps is great for me). I will play games like fear, Ghost recon, UT04 and 07, and cS.
The PSu is rated one of the "Best bang for your buck" on the thread, and reccomended, so I'll stick with it.
OH, and Andru, Thanks alot, i almost forgot :D. I'm not sure how to apply the thermal grease, so hopefully I can find some help online. I don't want to ruin that very pricy processor!
You might also want to consider a cpu cooler:
http://www.newegg.com/Product/Product.asp?item=N82E16835186134
totally up to you though. Can lower CPU temps by 10d. Will give you alot more OCing potential. There are better coolers too if you want to spend $50+.
7900gs will run fine, but it will definetely bottleneck your new system. WIth a killer CPU like that, you might be disapointed you can't run everything maxed. I would suggest an 8800GTS (460$) or a 7950GT.
Again, the system looks good and you can always upgrade the video card later when the 8800 prices drop. Really depends on your budget.
And as for your question about cables - everything should be included (as long as you don't buy OEM).
The Motherboard is "Retail", but the hard drive is OEM, so I need to buy some ide cables, or will they still come with the mobo?
anyone lese, i Ma interested in comments on the mobo, and the case, and ram.
http://www.xbitlabs.com/articles/mainboards/display/ga-965p-s3_3.html
Gigabyte GA-965P-S3 comes with a very modest accessories bundle including only the absolutely necessary items, such as HDD and FDD cables, two SATA cables, I/O shield, a CD disc with the software and drivers, a user’s manual, colorful quick installation poster in different languages and boxed cooler installation guide. As for the additional freebies, we can only mention a Gigabyte sticker. However, a small list of accessories like that is absolutely normal for a budget mainboard and hence cannot be regarded as a drawback.
What monitor do you have? If you're running at resolutions lower than 1280x1024, then you'll be fine with that 7900GS for a bit. Just upgrade when you're unhappy with its performance, but it should be fine for now.
Case is fine. Ram... great choice if you plan on OCing. If you want to save $35, go for the g.skill ddr2-800 2gb kit for $205 at the egg. Oh, and it may say "0.00" for shipping if you havent put in a zip code to the left of the shipping charge.
You'll get some sata cables with the motherboard.
"Case is fine. Ram... great choice if you plan on OCing. If you want to save $35, go for the g.skill ddr2-800 2gb kit for $205 at the egg. Oh, and it may say "0.00" for shipping if you havent put in a zip code to the left of the shipping charge.["
Awww... $32 Bux For Shipping!! Is te Corsair ram that much better? I hear Corsair is the absolute best, regardless of overclocking. i don't have )any_ experience overclocking, but I though i would give it a try, and make it to 3.0 ghz +. I Can i do that with this ram, and stock cooling, can I do that with cheaper ram and stock colling?
Oh, and how is that motherboard in terms of overclocking. i know it can handle quad core chips, which is important to me, but is it any good as a motherboard in general, or should I dish out for something a little better?
That mobo is great for OC'ing, stick with it or go with the foxconn to save $16, lol. An E6600 is 9 * 266 = 2.4Ghz... 3.0Ghz / 9 = 333Mhz. You'll definately reach 3.0Ghz with DDR2-667 ram (333.5*2=667). If you buy DDR2-800 Ram, it can definately run at 400Mhz (800/2)... yielding 9 * 400 = 3.6Ghz when keeping the ram 1:1. The stock intel cooler (according to the oc database in the intel cpu subforum) is good for about 3.4Ghz. So yes, you could definately reach 3.0Ghz with cheaper ram and stock cooling. Go with this ram:
$210 - G.Skill 2GB (2x1GB) DDR2-800 F2-6400CL5D-2GBNQ
