black_b[ ]x
- Jul 1, 2002
8800 GTS (g92) http://www.newegg.com/Product/Product.aspx?Item=N82E16814130312
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX Intel Motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
E8400 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
2x2GB corsair ddr2 800 http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
ZEROtherm Nirvana NV120 120mm http://www.newegg.com/Product/Product.aspx?Item=N82E16835887011
I'm re-using my CMStacker case, corsair 620w PSU, samsung DVD drive, and 73GB SATA raptor. Should i get a newer hard drive? its about 3.5 years old. I'd probably get a 400GB sata or maybe the 10k raptor.
Also, anyone have experience with that heat sink? will it fit on the motherboard? it looks like the north bridge fins are pretty tall, maybe i can just bend them inwards?
