Another ask for help....
Grimdj
OK Heres my stats...
Board is a Neo2 Plat
Stock hsf, but I will upgrade...(they got a nice Zallman at Fry's, hint hint)..if I have to. Temps not a problem so far tho.
Ram pc3200 Corsair value
Any suggestions? This is as high as I can get with my n00b knowledge :D
I'm sure I can squeeze a little more out of it.
Also, should I leave of the auto overclocking?
Thanks Gurus!
do you have a single 1g stick of ram or do u have 2x512 or what.. i dont know but if you have 2x512 but it in dual channel. also your volts look a lil large for that lil OC. i am, also in the process of OCing my neo2 plat atm and i dont even use that many volts for 2.55. srry for not that much help! hopefully more ppl can help
Thx for looking! :D I have 2x512 in slot 1 and 3. Doh! I backed off my clocking attempts, and I guess I forgot to lower the voltage back down. Told u I'm a n00b! Slaps self.
I just can't get it stable...even at this low an OC, Windows still freezes up occasionally, and any higher, and it locks at load up. Maybe I have a bum chip? Maybe RAM is too low speed? Frustrating compounded even more with the fact that I don't have alot of OC experience. UGH! (Feel better now) :D
