Atherton213
- Dec 21, 2004
ok... my 9800 pro i thought broke... was gonna upgrade to pci-e and stuff... but now i just will build a whole new system end of the year... my 9800 pro works in WoW but only in windowed mode.... the shadows are all messed up too... it also works in a few other games... but artifacted and just bad... checkered pattern white boxes.... so i got the zalman cooler for it thinking it was overheating.... but that didnt really help... so now its finally at that point where i wanna play some newer games and games i have that it doesnt let me play...soo which should i get... dont want to spend alot... just something to replace... and be bit of an upgrade... i have a 3500+ 1GB of ram....
choices??
x800gto
7600gs
6800xt
i think all those are in the 130-150 range on the egg..... so if anyone knows of something better than those please tell me... and i dont want anything like "if you spend an extra $20 you can get this"... if at all possible i want it closer to the 130 range... and after rebate doesnt count....
thanks!
choices??
x800gto
7600gs
6800xt
thanks!
