OK, im new to OC'ing.. heres my specs:
Asus p6t dlx
intel 920
ocz 2x3gb ddr3 1600
corsair tx750
msi gtx260
corsair tx750
antec 1200
thermalright TRUE 120 Push/Pull with antec tri-cool @ 1600rpm blowing out back of case
so i entered bios and pretty much matched the settings that kyle benett used in the p6t overclocking video;
vcore 1.33
dram voltage: 1.64
disabled speedstep
20x multi
185 bclck (3.7ghz)
ddr1533 mhz i think..
Running p95 and using realtemp v2.9 im getting temps of up to 84 deg C load after only about 20 mins of testing. I'm wondering if there is any way to adjust some of my voltages to lower this? or do i have to improve my cooling somehow? I will try the antec fans on 2200rpm tonight and see if that makes a difference.. maybe some 38mm thick fans instead of 25mm?? any help or advice would be greatly appreciated... thanks.
Asus p6t dlx
intel 920
ocz 2x3gb ddr3 1600
corsair tx750
msi gtx260
corsair tx750
antec 1200
vcore 1.33
dram voltage: 1.64
disabled speedstep
20x multi
185 bclck (3.7ghz)
