mulpsmebeauty
- Aug 1, 2004
I have a BFG 6800U OC arriving tomorrow (425Mhz core, 1100Mhz memory). I haven't overclocked anything before, so I'm not necessarily interested in tweaking it to its limit. I'd just like to push it a little bit a above the levels a lot of GT owners are getting ;-)
Does anyone know if BFG cards come with software that allows the cards to be overclocked? The software details on their site imply not. If this is the case, what do I need to use to overclock? Will it allow me to monitor the card temperature?
Can anyone recommend what sort of levels I'd be safe to put it up to, without being on the limit, or is there no way to tell? I'd hate to hear a comedy "phut" noise from inside the PC case as it gives up the ghost 20 minutes after it arrives...
Cheers for any input you might have...
