Another 512 of ram?
sdk
Specs are in my sig. On the way are a IC7G and a 2.4c which I sold my proc and mobo + some cash in my paypal I had for that. I have 512 Corsair XMS 512 PC 2700 and I was thinking of getting another 512 to give my self a gig. It runs me about 165 canadian shipped for it. What do you guys think I should doooo?
unless u doin heavy video design or wanna play hl2 or doom3 with max settings dont buy the gig 512 should suit u fine, and besides who knows when those 2 games are gonna be out anyways:confused:
everyone here is gonna tell you more ram never hurts. if it is in your budget, then go for it.
in sandra the 3 default ram benchies my scores are like a few cm behind the lowest
2200 ish ish for each in that area
i am getting a new mobo so i was thinking dual chan and up the fsb?
i bought this ram cuz my board is rated for 2700, tho the new is over 3200, so yeaha
dual channel will definatly give you noticeable improvement.
Ya if you have the pay to spare then get yourself the added ram and running them in a dual channel setup would be perfect.
if i got the same stick of the same site again, will i have any major probs setting up dual?
is 2 x 512 of 2700 better than 512 of 3200?
ty
btw ic7g supports dual rite?
Hmm... If you have a 2.4c on the way, which uses an 800mhZ FSB, which is 200mhZ actual FSB speed, and you have ram that maxes out at 166mhZ (333 dual pumped)... Then your processor and RAM won't be running at a 1:1 ratio... So, correct me if I'm wrong, but wouldn't getting 512 of pc3200 or pc3500 still be better than 1gb of pc2700 running at a divider?
I dunno, if it were me I would probably look into selling the current pc2700 stick and buying two pc3200 sticks (even if they are 256 a peice, you'll be running in dual channel).
Just my two cents :cool:
yeaha I was thinking about that, any other ideas?
CORSAIR XMS3200 512MB DDR 400MHZ 184PIN CAS2-3-3-6
i can get that for 162 bucks, which is about 20 candian more than the 2700
Looks good, however I'd probably try to find 2x256 sticks to run in dual channel, but I dunno how that would fit into your budget.
I'd post some prices, but I don't know anything about Canadian pricing... However, it shouldn't be too much more for 2 256 sticks...
Yeah maybe sell the stick you have and buy 2 of the the PC3200 in either 512x2 or 256x2...
