another 3DMark 2001 score question
planetary
I just built a system, and for some reason in the ATI control panel under SmartGart it says my AGP Acceleration is "Off". AGP is enabled in the bios. Here are the specs:
Chaintech 7KJD
Athlon 1700+
512MB PC2100 memory
ATI 9700 Pro
Omega 3.10 driver
Windows 2000 Service Pack 4
Here's the score: 10582
Does that seem right? Is Smartgart wrong?
Thanks.
LOL yep the board drivers aren't there. 13000+ isn't out of the range of that system at all if the chip and 9700 overclock moderately well
Originally posted by ambiguicom
Install your motherboard drivers.
It has an AMD 761 Northbridge, and a Via southbridge. I have installed the latest Via Hyperion drivers, I guess there are a couple of AMD drivers I'm missing, huh?
Use 3dMark2001 SE, you'll get a good sized boost in points probably. When I went from 1st to 2nd edition, I got an extra 1k :)
Bah. I went to AMD's website, got the Win2k AGP patch, installed it, rebooted, and Smartgart still says AGP acceleration is off. I set it to 4x, it tells me I need to reboot, I do so, but when it comes back up it still says AGP is off. I don't understand. Anybody? Please?
