I've built a few PCs before, but this will be my first water-cooled. My objectives are pretty much just to water cool and keep everything internal. I'm not doing SLI, I don't need to OC much, and making it quiet would be great, but not the most important thing. I just got the new machine up and running on air (stock). Here are PC the specs:
Intel Core i7 920
EVGA 132-BL-E758-A1 LGA 1366 Intel X58 ATX Intel Motherboard
EVGA 01G-P3-1287-AR GeForce GTX 285 SSC Edition
Western Digital VelociRaptor WD3000HLFS 300GB 10000 RPM (2, in RAID 0)
LG Black LG Blu-ray/HD DVD-ROM & 16X DVD±R DVD Burner SATA Model GGC-H20L - OEM
OCZ XMP Ready Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory
SILVERSTONE DA1000 1000W ATX 12V 2.2 & EPS 12V SLI Ready CrossFire Ready Modular Active PFC Power Supply
Lian Li PC-V1200B Plus II Black Aluminum Mid-Tower Case
I plan to WC the CPU, NB/SB + mofsets, and the GPU. The only WC stuff I've bought so far has been the water blocks:
EK-Supreme Universal Premium High Performance Water Block (1366 Compatible) - Acetal
EK-FC285 GTX SLI Water Block for Nvidia 285GTX - Acetal
EK-FB KIT EVGA X58 Full Board Northbridge/Southbridge Water Block- EVGA X58 3SLI -Acetal (mofset block also)
It looks like the pump to get is the Swiftech MCP355 with the XSPC res/top. I can fit a triple rad at the top of the case but I' sure need more than that. I can put a single rad in front at the intake fan, or relocate the hard drives and put a double rad on the bottom of the case.
So, here are my noob questions:
1) Triple rad + double or single?
2) Can I get by with normal sized radiators like the Swiftec or should I go for the fatter ones like the XSPC or Feser? I know everyone has their fan of choice. I guess which fans to get will depend on which rads I get. The less noise the better, but getting the right radiators is more important.
3) Will 3/8"ID 1/2"OD be OK or will I need bigger tubing to get enough flow? I plan to use compression fittings if that matters at all.
4) Will the MCP355 be enough for this loop or will I need to split it up into two loops?
Like I said, the only WC stuff I've bought so far were the blocks. I'm not really committed to any other specs. Also, I'll crank down the OC to keep all cooling internal. I won't say money's no object, but I will spend the extra to do it right.
TIA,
Joel
Intel Core i7 920
TIA,
Joel
