Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Unless you plan on doing a ton of parts it is not worth it for the average person. I would suggest finding a local plating shop or paintball place, both will usually be able to help you out if they do not have the ability.
bunch of anno places that do paintball stuff. Kits are pretty expensive so unless you are going to make a business out of it, you should just get it done by someone
