We have this annoying virus at one of the computers at work that is not supposed to be connected to the internet. It must have gotten it from a flash drive. It has symantec security installed, but it is not updated of course. I disabled the antivirus and installed Avira thinking that it might catch something. I couldn't update it of course because I can't connect to the internet. It did actually find some infections and I deleted them, but the problem remained. I also installed the latest version of Advanced system care, and it did its things but still. I then installed Malwarebytes and did find some infections as well but it also didn't help with the problem.
The symptoms are like this:
It makes infected folders hidden and label them all as system files, which means I won't see them unless show hidden files is checked and hide protected system files is unchecked. And even if I do this, it will go back to the original settings meaning settings in folder options doesn't remain to what I set them. OS is xp.
The thing is that I can't connect to the internet in this specific pc because it has sensitive info. But, as far as I know, some antivirus programs can be updated via loading an update file that can be downloaded off the internet from another pc.
What do you suggest I do ? The flash I used to transport files into the pc became infected as well and i tried to clean it with another pc having avira and malwarebytes updated but it didn't get removed. !
Do you know a virus with these kind of symptoms ? If I know it, i'm sure I can find a removal tool for it. I'll keep trying to remove the virus from my flash to see which program can get rid of it and see if I can get its name.
I did a quick google search and it sounds like this is related:
http://answers.yahoo.com/question/index?qid=20080527074654AAHNpBX
What do you think? and how do I clean a pc that can't be connected to the internet from all possible infections?
Thanks.
Thanks.
