D
Deleted member 88227
Guest
I need to figure out a way to fix this issue at hand. The LEDs on this unit are extremely bright, in total darkness with just those lights on it lights up the room well enough to see pretty good. Especially the blue LED. That sucker is BRIGHT. Here is what I want to do.
1. Disable the light completely.
2. Dim the light so it's not as bright.
3. Change the color of the blue LED to a green LED that's not as bright.
If I'm lucky, we can do this with just a firmware flash/edit but I'm afraid I'm gonna have to take it apart. Any suggestions?
