Annoying iTunes problem
Spaceninja
I have a new iPod Classic 80 gig and I am of course using iTunes now. My problem is this, I have compilation discs such as soundtracks and things of the sorts. How do I make them all appear as one album in coverflow? I can't find any option anywhere.
This is on Windows as well, just in case that makes a difference.
Thank you.
I've got the same problem.
One option is to change the artist to "Various Artists" for the whole album. Then change the name of the song to "Song title - Artist name". Then they'll show up as one album in cover flow. I tried making "Various Artists" the album artist while leaving the song artists the same, but that had no effect on Cover Flow. If you figure out a trick (like making Cover Flow rotate by Album name, rather than Artist name), please tell the group. ;)
Noticed that it is doing it for some albums as well, I have like 10 different labels for one album. It is all the same yet for some reason it decided to break it up. All the id3 info is the same, I made sure of that.
I do sort by albums but then I dont use coverflow. I hate it when my ipod 80 classic dont resume on last track play after charging/syncing. Very annoying to find that last track
get info on all the tracks in the album, and check the box that says "Part of a compilation" under the info tab
as long as they all have the same album name, they will show up together.
