I have tried and tried to remove the annoying buzz from my speakers but am running out of alternatives. Any suggestions:
M-Audio Soundcard - Running to a Rokit 10s Sub and Two Rokit 5 powered studio monitors.
I have put a ground loop isolator between then sub and soundcard thinking I am getting feedback off the power supply but that doesn't help. Should i also do the same between the sub and the monitors. I am using RCAs to connect everything up.
My Mac Mini never did this, but this Dell does. ARGH.
Any suggestions would be appreciated.
