nonsequitur
- Feb 13, 2002
as the subject line suggests, i'm pretty annoyed with the home routers i've purchased for my home cable modem connection.
i don't consider myself a power user, but it seems web surfing/ irc/ and occasional bit torrent usage (combined with my roommates occasional use on her own pc) brings my home router to it's knees on nearly a daily basis.
i am currently using a dlink-704p, and have used a smc xxxabr ( i can't remember the model number at the moment).
i'm seriously considering plunking down the $300 or so for a 'simple' cisco router to add to my network. i have no ccna or any cisco cert, but i'm fairly confident i can get it to work, once i figure out what the heck to get. ( what would the right model be? )
i'm also considering turning an old compaq into a router with one of the linux/bsd solutions out there. would that box need to be in between the cable modem and the first switch? (if so, i'll need to rewire a fair amount)
i might try out the linux router situation first just to see how clunky a solution it might be, though i'm concerned about the power usage from having that pc on 24/7.
would a competant computer trouble shooter be in over his head with cisco equipment, as it's an entirely different can of beans?
thanks to all who read this lengthy post...
