MarkIpswich
- Jun 10, 2020
I've got an Anker Power Bank 26,000mah (not the Power Core +)
Input: 5V ⎓ 4A (5V ⎓ 2A Max Per Port)
Output: 5V ⎓ 6A (5V ⎓ 3A Max Per Port)
I've been using that to try and install a Adafruit PiTFT 2.4" HAT Mini Kit - 320x240 TFT Touchscreen on a PI 3B+ model. I am unable to as I get the low voltage warning, as it needs a bit more power to use it (3.3a)
I could use a plug but I just want to use a power bank with it.
I do believe I need a dual USB and micro USB cable so I can get enough power from the bank to the PI board for it to work.
Is that correct?
I need someone to be 100% sure it will work with using it.
If yes, then would this be the correct one that I need?
StarTech.com 3 ft. (0.9 m) USB to Micro USB Cable With Power Delivery - Dual USB 2.0 A to Micro-B - Power and Data - Y-Cable - Micro USB Cable (USB2HAUBY3) - USB cable - USB to Micro-USB Type B - 91 cm
It's from https://business.currys.co.uk/catal...-cable-usb-to-micro-usb-type-b-91-cm/P129791P
Is that correct?
