How does android select and prioritize which AP and band to use?
I ask because my Note 4 w/5.1.1 can be sitting on top of my router and it will camp out on the 2.4GHz band. Only way to get it on the 5GHz band is to disable the 2.4GHz radio or use separate SSIDs. Is there some setting I'm missing that can prioritize connecting to 5GHz AP's without resorting to separate SSIDs?
