Android 3.1 Wifi issue.
C7J0yc3
Hey all, got a strange wifi issue that I can't seem to figure out. Before upgrading my A500 to 3.1 everything was great. After upgrading to 3.1 any network I connect to with security on it will not hand a DHCP address to my tablet. It just goes through the connecting, acquiring IP, disconnected/remembered cycle about 4 times then stops trying. If I manually assign an address to it everything works just fine. If I delete the network and re-add it, I have the same problem. Any open network connects without issue.
Any ideas on how to resolve this issue?
notarat
Are you entering the passphrase or key when trying to join the secured network? (just asking because you didn't mention doing that part. I have to enter the passphrase in order to join my protected Wi-Fi network)
C7J0yc3
If I delete and rejoin the network, then yes I have to put in the WPA2 key, however the device still doesn't join the network. If I try to join the same network from any other device there isn't a problem.
AQ_OC
Are you using the real 3.1 that starting going out yesterday, or the fake one?
C7J0yc3
That is the version I am running. I didn't use the modified update.zip for root, and have not rooted the device.
AQ_OC
Most think that is an early beta of 3.1. I got the official update to 3.1 on July 4. I wonder if the early beta is your problem.
C7J0yc3
Seems I am not alone, and looks like the issue was fixed in the main release. The fix is to delete the file /data/misc/dhcp/dhcpcd-wlan0.lease and then reconnect the tablet to the network. This fixed the problem instantly.
rsharma
Hi I have the same problem, Can you advise how to I delete the file you mentioned above. I am not very familiar with Android OS and how to make tweaks.
C7J0yc3
Firstly you need to have root access on the device.
Next you can delete the file one of two ways
1: Through a file manager like root file manager
2: Through a terminal
I did it through a terminal using the following commands
su
cd /data/misc/dhcp
rm dhcpcd-wlan0.lease
after that everything was fine, and no reboot needed.
rsharma
Hi after breaking my head over how to root. I just did a factory reset and incidentally the factory reset loaded 3.1 directly and the problem of connecting with wi fi was also resolved.
Thanks for everyone's help. My ACER A500 does not allow me to download any root file manager. It says that it is incompatible with my device. Any suggestions for this problem for the future
