burningrave101
- Sep 9, 2003
Which do you prefer and why? I'm sure most of you will say digital is better but what about the refresh rates of digital vs analog? For instance if your LCD can run 1280x1024 @ 60Hz digital and 1280x1024 @ 75Hz analog which is better? Picture quality is suppost to be a little better on DVI but what about the refresh rate of the screen? Do you notice a difference when your like dragging windows across the screen? I'm doing some testing now on my Hyundai L90D+ and it appears there is less "ghosting" when dragging windows quickly across the screen when using analog. The picture quality also seems to actually look better but that may be because the DVI on my 6800GT isn't as good of quality as the DVI on ATI cards, or so i hear.
There seems to be quite a few issues with the DVI port on 6800's and i'm not sure if its the video card itself or just the drivers.
http://www.hardforum.com/showthread.php?t=831813&highlight=DVI+6800GT
http://www.hardforum.com/showthread.php?t=833025&highlight=DVI+6800GT
http://www.nvnews.net/vbulletin/showthread.php?t=40556
What do you guys think?
