DiscipleofWar
- Sep 21, 2012
I have a pretty straightforward question - I have an older Yamaha RX-V870 5.1 receiver / speaker setup, and I want to plug this into my PC and take advantage of the 5.1 surround.
There seems to be very little info on how to connect an analog 5.1 setup to a PC (clearly because this is now very old).
I just need to know how to correctly connect the receiver and the PC so the computer can play 5.1 sound. My mobo is newer and has all the standard analog audio ports.
Do I need to run separate connections from the front/rear/center out ports on the receiver to the different ports on the PC mobo?
See the following images for what I have to work with. I've been running audio from the "CD" RCA ports and that works for stereo, but not 5.1.
I'm assuming Low Pass is for the sub...
