AN7 - Onboard lan cuts out.
Roach
Ok, I've been using this board for awhile and overclocking has been good. Now though after 10 minutes the lan will cut out and I have to restart to get it to work again. It first started when I was doing 222x11.5... So I turned it down to 220x11.5 and that seemed to solve the problem. Now its back again, so I tried stock mobile speeds, samething. I haved tried multiple bioses with no improvement, so I finally popped a 3com 10/100 NIC in and that seemed to fix the issue.
I really liked the onboard LAN feature of this board and I hate having to have an extra PCI card in my computer. Is there anyone that has had a similar problem and been able to fix it? I've tried every bios config I could think of but nothing is helping.
Update - Now onboard sound decided it wanted to join the party.
Dying motherboard?
Would increasing my northbridge voltage help at all?
The southbridge chip is probably overheating. Try adding a heatsink to it.
Good lord, I just touched the southbridge and I think you might be right. Any suggestions on a good heatsink and some adhesive compound? (No mounting holes) :(
i have the same mobo and my stock nb fan crapped out, i just replaced it with the copper vantec chipset cooling kit with no probs.. temps went down a bit compared towhat they used to be and very easy to install..
Yea, the Vantec Iceberq kit is perfect. It's what I put on my NF7-S, the smaller heatsink (copper colored aluminum) works great on the SB, just stick it on with the included thermal tape. Also the real copper HSF is a perfect replacement for the stock northbridge HSF and will cool a lot better than stock too.
from newegg
from SVC
from newegg
from SVC
Very cool, I have a Vantec Iceburg4 pro that I put on my northbridge with a little modding but has a very annoying blue led that doesn't go well with my other lighting so that would be a perfect replacement. The only thing is that I would have to switch the two pin connector with a three to fit the AN7 northbridge power connection.
Thanks for the post.
Roach said:
... The only thing is that I would have to switch the two pin connector with a three to fit the AN7 northbridge power connection.....
I think the AN7 has four 3-pin fan headers so you could just connect to one of those.
