Gollum0000
- Jan 31, 2004
I recently purchased a new comp. Ive had it for about a month now and its been pretty troublesome. Defective RAM, defective monitors (yes, plural), and a bad chipset fan on the mobo. Most of my problems are fixed except the motherboard is still giving me some trouble. Here are my system specs:
Athlon XP 3200+
Abit AN7 (Bios v. 14) (nForce v. 3.13)
Corsair TwinX 1024-3200LL
ATI Radeon 9800 XT (4.1 Catalyst)
Viewsonic VP171
Maxtor 120GB SATA
Thermaltake Silent Boost
Enermax EG465AX-VE (W) FMA
Occasionally when I start up my system a siren goes off on the mobo. Also while doing nothing in windows it will occasionally make a high/low beep. Im pretty sure this is due to temperature levels. When the siren would go off I woudl check my chipset temperature and it would go to like 120 celsius. About 15 seconds later it went back down to 28ish. Think if I replace the chipset fan w/ a crystal orb it woudl be better? (unfortunately the crystal orb doesnt fit so Id have to use thermal adhesive). Any suggestions?
Athlon XP 3200+
Viewsonic VP171
Maxtor 120GB SATA
