AN35N400 Any good?
I've always been a relatively cheap person. This mobo is only $70 at my local frys and I wanted to buy it so I could overclock my Athlon XP 2500+. I just wanted to know if this mobo was good enough to overclock to a 3200+. And BTW, I'll have some better memory if/when I buy this mobo.
Edit: Sorry forgot a link to some specs.
Link
You sure that's what Fry's is selling? I had the AN35N-Ultra, which I think is what they sell at Fry's, and it OC'd easily and ran stable once I upped the vcore to 1.7 from the default 1.65. You just set the BIOS to optimal and it upps the FSB to 200 for Barton 2500+ and it becomes a 3200+.
I would suggest the AN35N Ultra instead since it features a dual channel memory interface and is less than $65 on newegg.
The AN35N400 has the single channel version of the NF2 Ultra 400 chipset, which still performs quite well and is identical in every other way (same PCB I believe).
Given that newegg sells the fulll dual channel + LAN version for $61.99, I wouldn't pay a penny more than $57 for the single channel variant.
The AN35N ultra 400 only allows for 2.7V for the RAM so don't expect too much from there. I'm running mushkin level I 3500 (CH-5) at 440MHz 2.5-3-3-8 with auto Vdimm and she's stable as a rock. Great mobo for the dough and a wonderful learning tool for the n00bie OCer. ;) Here is a link to my data and a few others: FSB data for AN35N-U
I got my AN35N Ultra 400 back in November when Newegg had them for $49.99. stable board, sound is good. the VDIMM only to 1.7 is a big downer as Corsair XMS likes to run at 1.8.. other then that..
was a great, cheap last upgrade for my XP chips before the big move to 64bit. My OC was just as good as my Epox until I hit the 1.7VDIMM
I just finished a system with this board, it seems to be running nice so far
no o/c yet, but its coming soon. I want to work on cooling first.
I was using 2 x 512 Mushkin Basic PC3200 2.5-3-3-8 and it was rock solid stable. Didn't have to touch the vdimm.
Problem I had with mine was a high pitch tone coming from the coils beside the socket when the system was idle. Probably couldn't hear it if you had loud case fans and HD, but it was enough to make me return it and get a different board especially since it was reported by other users as well.
Using a pair of my Sammy DDR333's @ 2.7vDimm, I've hit a 240FSB with a 1:1 Ratio.... stable @ 230 FSB....
Highly reccomended board.
Lucky bastard! My Samsung 333 won't go past 180 with any voltage :(
I have my 3200xms memory running at about 420mhz with like 210mhz fsb, on a locked barton 2600+ running at like 2.4ghz as of right now.
I am going to try to pick up a Mobile Barton and o/c that.
If only it had a few more tenths on vDimm, we'd have a perfect board.....
THIS IS A PERFECT EXPLANATION! Do not get a AN35N400 for any reason. However, a AN35N-Ultra will set you back about $60 on newegg and will OC to outerspace if you rub it right. That is what i am running. I did mannage to fry 1 BIOS chip however when I set the FSB to 203MHz. I think it was some short of freak random occourence. I got a new chip and all is well.
