AN35N Ultra400 memory divider issue
MiXdNuTs
I have the shuttle AN35N Ultra400 mobo for my system (see sig) and I can't get the FSB to budge past 200. This is not the ram's fault because I tested it by going from 166 to 170 and it still crashed. I fried my first bios on this motherboard by trying to get it to 205. Does anyone know if the memory dividers (1:1, 5:4, etc.) are working on this motherboard and if so, where are they and what does it call them. I can't seem to figure this out but I know for a fact that people have gotten this board above 250! Check it out here.
Are you running in Dual Channel? Sometimes this can limit your overclocking.
What exactly happens when you try to go past 200? Does the system not POST? Do you fail prime95?
Find out your limiting factor through tests, i.e. if it is your chipset, memory, or cpu. Then up the voltage in that area.
Updating your BIOS and all drivers (i.e. chipset) will help too.
I'll be happy to help you out, but I need more information.
I am running Dual channel. Channel 1 has 256X2 and channel 2 has 512X1. RAM voltage is at 2.7 and stable for Memtest86. The CPU does start to fail prime95 after about 2 Hrs at 2.5, but it is ROCK solid in everything else so I dont care about that. I just wanted to run something like a 210 or 215 FSB so that I can get more out of my CPU. I like the feel of a higher FSB on AXP CPUs because it is just alot smoother somtimes. I want a 2.4GHz clock with as high an FSB as possible, and my RAM is not the limiting factor. It is either the CPU or mobo at this point.
Are you sure its not the memory? You are running 3 sticks. Some motherboards cannot take that, and allow a high FSB. Might want to check into just using the 512 stick for testing purposes.
Also, what cpu voltage are you running?
What are your cpu idle and load temps?
I am guessing that you just need to up your cpu voltage, or maybe even your chipset voltage. Try one, then the other.
