AN35N-Ultra RAM slots
Helmut
This one is totally baffling me. . .My system boots up just fine with a single RAM stick in Slot 3. If I put it in any other slot, it will not boot and gives me a memory error beep. Resetting the CMOS does not work.
This is not a dual-channel problem as I am just using 1 stick at a time, but I have tried 3 different sticks and they all do the same thing.
Any ideas would be greatly appreciated. About all I've come up with so far is RMA, which will definitely be an absolute last resort.
I reflashed the BIOS to the newest version last night and that still didn't work.
I'm pretty sure the RAM is not the problem. All 3 sticks that I have (Crucial, Kingston, Kingmax, all 3200) work when I have them in slot 3. The problem is when I put anything in slot 1 or 2.
PSU is fine
3 different brands of RAM is not & most likely the problem.
As DM8 mentioned this board is picky about RAM, this also includes mixing brands and memory chips even if they are all rated for PC3200
Check and see if any of them are using the same memory chips.
If so there is a decent chance that the ones using the same memory chips will work together.
Also what are the default timings of the individual sticks? Possibly using 1 stick you could change BIOS settings to 166FSB & Expert memory settings with 11-3-3-2.5 timings, save, shut down, insert another stick and restart.
Regards, Szandor
Maybe I didn't explain this right. . .let me try again.
At any given time, I only have 1 stick of RAM on the motherboard, the other 2 slots are empty. Anytime I have a stick in slot 1 or 2, the system will not boot and will give me a sequence of long beeps. I'll try to draw a little picture below if this still doesn't make sense.
Slot1 Slot2 Slot3 Result
RAM none none no boot
none RAM none no boot
none none RAM boot
RAM RAM none no boot
RAM none RAM no boot
none RAM RAM no boot
RAM RAM RAM no boot
The table is the same for the 3 different brands of memory.
What settings and memory timings are you using? Default\Auto? Expert with specific timings? Are you saying you've tried 3 sticks from each of the different brands or you have 1 stick of each brand?
Regards, Szandor
Ohhhh! I follow you now, I thought you meant you were using different brands at the same time. My Bad!
RMA that MoFo MoBo AsAp!
Regards, Szandor
Too bad you had problems Helmut, my AN35N has been flawless. I'm currently running a XP1700 DLT3C @220FSB x 11 on 1.75V with Buffalo\Winbond PC3200, Prime and Memtest stable, runs 38/46 on V-12 at a quiet 3000rpm.
Regards, Szandor
Yeah. I've heard great things about these mobos, and my RMA will just be an exchange. Actually, besides the RAM slots, this board is amazing. My 2400+ is also awe-inspiring, and it WON'T be getting RMA'd :D
Glad to hear you haven't given up on it. I'll be interested to hear how you make out with your new board w\ the 2400+
Good Luck!
Regards, Szandor
I got the a35n ultra 400 when they had that $15 MIR back in November. The board was cheaper then to for some reason. Well I never got my rebate after 8 weeks and shuttle wouldn't comment so Newegg refunded the rebate amount. then 2 weeks later I got the check lol. So I got the board for $35.
Biggest problems I've had are onboard sound has a lot of noise from the other components if you really crack it and put on a headset can be annoying until you get into the game.
I can't tell when the thing is in Dual channel. I've got 3 sticks of 512 3200C2 XMS but I've never seen it say 'DUAL CHANNEL' like my old Epox nforce2.
Other then that.. the VDIMM max is to low.. I like the option to at LEAST hit 3.0Vdimm.
Still best Shuttle board I've used. I remember m AK31a I had back at the start of the xp chips. It wouldn't boot sometimes, you couldn't use 3 sticks of ram because a bug (not like anyone had three sticks of even 256m then anyway.)
