I found out something rather exciting a couple of weeks ago. As it turns out, both of my Q6600 C2Qs are G0 SLACRs. (Or one was, and I found a second in the course of building my dad's computer. My month old B3 stepping works just fine for him...
Now, I haven't overclocked since socket A Athlons (the good as gold ~1.8->2.4ghz ones.) The time before that was a pair of Celly 366@550 on a BP6. You get the idea - I'm cheap, lazy, and want guaranteed stability if I'm going to the trouble.
The G0 stepping Q6600s seem ready made for me!
So, without further ado, let's present my victi^M^M^M^M^Mvolunteers:
http://www.flickr.com/photos/silicondependency/2045334728/
Meet Balthasar and Melchior - two of my desktop machines. (Before you ask, yes, there is also a Caspar, but it's hiding in a rackmount and is merely a Socket939 Athlon 4600+. They were named after the Magi computers out of Evangelion.)
Specs:
Balthasar, On the left:
Q6600 G0 Intel Core 2 Quad
Gigabyte P35-DS3R
4gb Rendition (cheap) DDR2-800
EVGA 7800GT CO 256mb
5xMaxtor 500gb SATA2
Antec Truepower 550watt
Lian Li PC-70 mkII
Kubuntu 7.10 64-bit
Melchior, On the right
Asus P5K
2gb OCZ Platinum DDR2-800
EVGA 8800GTS 640MB Superclocked
1xMaxtor 500gb SATA2
Lian Li PC-70 mkI
WinXP/WinXP-JP dual boot
Balthasar, with it's 4gb of ram and mere 7800GT runs 64-bit Linux as my desktop solution. I'm hoping to wring a few extra mhz out of it, but it isn't that crucial. Melchoir, on the other hand, is my "Wintendo" for playing my video games and I'm planning on wringing it till it cries
As long as I don't have to do too much work in the process.
Now, the tools of the trade:
http://www.flickr.com/photos/silicondependency/2045334738/
A pair of Thermalright Ultra 120 Extremes, with Scythe S-Flex SFF21F 120mm fans and Arctic Silver 5.
I've never used Arctic Silver before, but I figured I might as well *try* and do it right this time...
The fans were a random pick off the shelf but, in hindsight, they seem to be well regarded. 1600RPM, 63.7CFM, 28dBA, 0.2amp.
The heatsinks themselves need no introduction. However, in a fit of laziness/fear of voiding warranties/destroying $800 of equipment, I'm not going to lap anything. So there.
The first problem to overcome is the cases. The Lian Li PC-70 is an outstanding case - massive, easy to work on, and with a beautiful fit and finish. I love them. However, they're a bit of an older design, and are limited to pairs of 80mm fans for cooling - 6 in total. (2 at the front in front of the HD cage, two behind the CPU socket, two above the power supply.)
Now, I've never done much with the stock loadout of 4 - I even think one of the fans in Melchior is half dead, ATM. So, I decide a cooling refresh is required and back to the store I go.
While I was at the store, a nosy clerk decided to see if he could offer any advice. I told him which cases I was trying to cool and he told me that they were kind of old, and maybe I should replace them.
Now, they *are* older cases, but I'm not about to replace $600 worth of near-mint Lian-Li Full Tower cases for the privilege of using 1 120mm fan instead of 2 80s! I wasn't sure if I should laugh in his face or just start to cry...
http://www.flickr.com/photos/silicondependency/2045334744/
I ended up with a pair of silver 4-channel fan speed controllers good for 18 watts/channel, and 8 shiny new high flow 80mm fans. They're just cheap ones, though - I was going to buy Panaflos until I saw the price the store had on them - a tear inducing $14.95/ea. What I ended up with are rated at 0.28A and have good airflow at 12v and are quiet at 7v. I'll be using the fan controllers to crank up the cooling when I'm playing games.
Six of the new fans are destined for Melchior. The leftover pair will probably end up in Balthasar along with the best fans out of my older stockpile of junk. (Including a pair of Nidec Beta SL 80mm)
I'm going to start off with Melchior for now, and see how well it works out before I break down my main desktop. Well, that and I have a couple weeks vacation time off work and I want to get some PC-gaming action going on.
I'm downloading some benching software right now, and I'll be back with the stock/Intel HSF numbers in a bit.
Specs:
Gigabyte P35-DS3R
Lian Li PC-70 mkII
Kubuntu 7.10 64-bit
Asus P5K
Lian Li PC-70 mkI
