I was looking at a heat exchanger we have at work. They are used to cool our electronics at a paper mill. The temps in the mill can get to 125+ degrees on the mill floor. This makes me wonder about it's possible use for a home PC.
Pic:
It is all copper tubing with aluminum fins on on the outside. The tubing runs back and forth multiple times though the fins. (See the top of the pic.) The shroud is AlNiCo and painted grey. Between the shroud and heat exchanger fins is a foam type material to ensure the airflow goes through the fins..
The mounting holes look and pretty much measure up to 140mm fans.
Any thoughts? I can get a new one for free to try out. (this is an old one that sprung a leak after 5 years)
Pic:
