I had a thought about using TEC or peltier... whatever you want to call them.... a litttle differntly than most people use them.
Usually they are put directly on the processor in order to keep it as cold as possible. The major problem with this is obviously condensation.
Here is my thought.... In order to eliminate the problem with condensation and use a standard heatsink/waterblock, why not use the TEC to chill the water to near or below ambient temperature. then just use a simple fan/ heatsink to cool the peltier?
Control for the TEC would have to include an ambient temperature sensor, a water temp sensor, and a CPU temp sensor. Basically the water would be cooled by the TEC to the point where it will not cause condensation at the processor.
I am planning on using the CrystalFontz 635 with the SCAB fan controller and the software would make it stupid easy to integrate. Super accurate temp sensors for the water, and ambient temperature, as well as the possibility to integrate a "one wire" humidity sensor to make the control perfect. (using humidity and ambient temperature you can caluclate dewpoint, the temperature at which condensation will form)
Anyone have any experience with this, or seen it done?
-Brian
-Brian
