An Affordable "True" Sinve Wave UPS?
Cyane
I had a thread up a while back, but was getting no answers. Since I bought my Enermax Infiniti, I've been unable to use it until I get a new UPS, so I'm stuck with my old 430 Thermaltake PSU. Can anyone suggest a decent and affordable (if possible) True Sine Wave UPS for a gaming PC?
Thanks in advance.
What you are looking for is a UPS that will output a sinusoidal sine wave. Read expensive.
I use Leibert products on my home theater systems and my test bench. No, no way could I ever afford these when they were new.
Unless you are running serious "mission critical" servers or work stations for most of us, the cost is prohibitive.
Opinion: A true double conversion UPS comes very close in performance.
These are referbs, meaning they were tossed, checked and fresh batteries were installed.:
http://www.upsforless.com/doubleconversionupss-1.aspx
This link explains the reasoning:
http://www.pcguide.com/ref/power/ext/ups/funcOutput-c.html
APC makes a few nice units as well:
http://www.apcc.com/products/family/index.cfm?id=165
Hope that helps a little;)
Be sure you aren't confusing "true sinewave" with "always online".
Personally, I would get a refurb APC SmartUPS from somewhere like ExcessUPS
I bought a used SU1400NET back in 2001 (built in 1998 I think) from "some local guy" over ebay. I've replaced the battery twice and it's still going strong. Note that I purchased a model which has a variable fan to cool the charger and inverter circuits. I could choose from an SU1000 with no fan or upgrade to an SU1400 with a fan.
