Mackintire
- Jun 28, 2004
Also i too wanna know USG vs Edgerouter if anyone has an opinion, The setup OP mentions he will get is pretty good, i was thinking of doing the same, USG - 24port POE switch - AP AC LR - etc etc. The thing i cant figure out is if the unifi products are required for them to work with the controller, as in, will edgerouter showup in the unifi controller, or will you in effect have 2 controllers??
Almost identical hardware, but use different firmware with a near identical base code. UNIFI is designed for small business with limited resources, Edgerouter has significantly more features, but the GUI isn't as pretty and you can't see everything from a single dashboard like you can when you use UNIFI.
Evidently you can build more complex configurations into a ERL and load that config into the USG. You may not see the buttons but config should be applied. Doing that same process on the higher models is a bit more difficult as not all the ports number and config are the same.
