No, the HD3000 Intel IGP does not even come close to comparing to any of the HD6000 series IGP or discrete mobile GPUs.
My friend has an Intel HD3000 IGP and a C2D, and yeah, it gets it's ass kicked by my netbook with a dual-core Atom and an ION IGP, which is still not as fast as an AMD APU.
I don't care how fast your CPU is or how many cores you have, if your IGP/GPU is lacking in processing power, you won't be able to play games nearly as well as another system with a slower CPU and a powerful GPU.
Intel designed it's IGPs for energy/cost efficiency, not performance. Though they have improved over the years, they still don't come close to NVIDIA or AMD IGPs.
are we talking about the same intel igp?
i don't remember the core2duo coming with sandy bridge hd3000 graphics
http://www.notebookcheck.net/NVIDIA-ION-2.24292.0.html
This link shows your ion getting beat.
how would you explain the hd3000 showing similar performance as a 6370m discrete in the benchmarks?
http://www.notebookcheck.net/AMD-Radeon-HD-6370M.40970.0.html
It is possible that Trinity may have L3 cache, but anything like eDRAM may not be profitable (though it would help performance immensely).I wonder if we could see onboard an A4 APU like the old L3 cache for Bulldozer boards?
for anyone looking for a a8 labtop.
Only one i have found so far is from gateway.
http://www.gateway.com/systems/product/529668847.php
629.99$ msrp.
I am still waiting for more a8 notebooks to come out. The gateway one looks pretty solid though.
But the hd3000 graphics don't even come close to the a8 or a6. Only way intel can compete with amd on the graphics front is adding a discrete card. Then your going to have short battery life and its going to be more expensive, not to mention they are going to be much more bulky.
at under 700$ its nearly impossible to beat the gaming performance this guys offer. Over 700$ its possible, but then again it is going to be heavier,and have less battery life.
Thanks man! So, graphics performance is decent with 1333, and there's room for improvement if you want to buy faster memory. Could make for an excellent value gaming platform if they keep the price right.
Battery life with discrete graphics isn't much worse than APU at the moment.
And so far it's 32nm APU vs 32nm CPU+40 nm GPU so they have 6-9 months of slight advantage before competitors go into 22nm CPU+28nm GPUs.
More expensive is just a matter of price and with die size diffrence beetween dual core sandy bridge vs 4 core apu guess who have more profit margins to cut in eventual price war.
Are you comparing the A8-3500M to the i3-380M + GT425M? While the battery life difference isn't that large, the performance difference basically says that the GT425M isn't a hell of a lot better than the 6620G inside the A8-3500M, and I think calling the GT425M 'discrete' is a long shot.
Until (and unless) Intel comes up with a mobile version of Pentium-G (the value/budget Sandy Bridge version of LGA775's pocket Visigoths - Celeron DC/Pentium DC), they have exactly diddly in the category. Atom is severely underpowered by comparison, and mobile i3 is too pricey. Expect trainwrecks a-plenty.
