HardOCP News
[H] News
- Dec 31, 1969
The crew over at Tech Report got a little hands on time with AMD's FreeSync technology at CES this year. Hit the link for the complete rundown.
i am curious to see if it really works on any monitor that is dp1.2a comp.
provided those panels support the DisplayPort 1.2a Adaptive-Sync specification
Nvidia:: Here's Gsync. A new amazing never before seen super expensive technology from Nvidia. Your Gods and master.
AMD: Here's FreeSync. A not new technology that's really adaptive sync that we resurrected with our label on it.
EVERYONE: Nobody cares. Where's your new CPUs AMD?
FreeSync is a gpu based feature, Adaptive sync is a monitor based feature. I think you may be just a little confused.
What's wrong with gsync?
G-Sync is proprietary. Meaning whoever wants to use must first get permission from nVidia to use it as well as make a deal with (pay) nVidia to use it.
Adaptive Sync is a DisplayPort standard. Optional for 1.2a and mandatory for 1.3. This means that it is a free use standard, anyone can use it and offer it with no additional fees.
Freesync is proprietary to AMD.
Adaptive sync is not madatory for 1.3Stop making sh** up.
It's currently the best available solution. But AMD does not support it so some of their fans are salty.
How is Gsync better than Freesync?
I'd much rather support open standards then some over priced doohiky like G-Sync.
"Open standard"?
Newsflash: Freesync is AMD proprietary
Adaptive-sync: Open"Open standard"?
Adaptive-sync: Open
Free-sync: AMD proprietary = true but it is just the name given for AMD GPUs to utilize Adaptive sync. Intel will likely have its own name as well but doesn't change the OPEN-NESS of Adaptive-sync.
Unfortunately, the word free is going to be a problem. New Adaptive-sync monitors (though touted to cost nearly nothing to implement Adaptive-sync) will most likely have a premium added to account for the new feature. It will obviously be lower than a G-sync premium, vastly lower with reason, but likely not the exact same as existing non-Adaptive-sync monitors.Don't forget FREE-NESS![]()
"Open standard"?
Adaptive-sync: Open
Of course a good rebuttal to the monitor price not being free and the fact monitor side of the implementation is called Adaptive not Free-sync, AMD could say the Free-sync side Driver is free, as drivers usually are.
Sure monitors with the support will be priced higher than those without it, but they aren't paying a company a handsome royalty to use it.
I will admit that I am very hopeful to see it as a set standard soon in every monitor.
Actually so far they have shown the same price as similarly specced monitors.
That has made them be a good 150-170$ cheaper than their gsync counterparts.
Still so much unknown. How smooth is it even though its putting a greater load on the GPU? Is it entirely drive in low level driver coding or is it an elevated process? Can we see it demoed fullscreen as well?
AMD isn't really being very open about its tech all things considered. Nvidia at least showed it and broadly so but with the AMD is tip toeing its general announcement has me a bit worried.
I want to see input latency numbers with it on and frame rate impact since it'll be loading all the work onto the GPU alone.
We need someone to do a proper review of Freesync and until that comes I'm going to remain skeptical.
Frankly with AMD's dodgy driver support in the past I wouldn't go for Freesync until they worked out the first generation kinks.
Say what you will about the cost of G-sync it works near flawlessly and that's in part because it doesn't require lots more processing from the GPU and it only needs low level driver support so I've yet to see it break outside of one or two games max.
The ASUS FreeSync monitor is IPS 120-144hz and $200 less than the ASUS G-Sync monitor that is TN.
