AMD64 stability problems, greatly appreciate any help
Cali3350
I have some problems with this computer...and i need some help. Im out of ideas on what else to do.
When playing games I would randomly get freezing (they would lock up, however i would still get sound. It was a very strange lockup). After running Prime 95 i found my problem - it would error out within minutes when doing the third test (the one that says "maximum RAM usage"). I assumed the problem was the ram, however memtest86 passes without a problem, so im lead to believe its perhaps the CPU that is at fault. The problem with this is that if i run the first torture test (maximum CPU usage) it will run all day without a problem.
To add more mystery to this for me, if i attempt to start the computer with my ram set to 166mhz the computer WILL NOT boot. It posts, however Windows immediately fails to load. Im stuck with 200mhz (with memtest86 says is fine, was just trying to test things).
Im at a complete loss as to what my problem may be, and was hoping one of you out there might have an idea.
GREATLY appreciate any help.
Thanks.
I'd try switching out the GPU.
If it's only game related then maybe graphics are what cause the freeze, check GPU temps.
Uninstall drivers, load in safe mode and run driver cleaner to remove leftovers. Reinstall drivers and try again.
You can also try to focus on stressing the GPU alone (As alone as possible...) by running 3dmark06 or 05 in loops.
If the GPU is not it, then maybe the PSU isn't holding up.Try switching out PSU's.
On AMD64 heating isn't an issue (99% of the times), so unless your mobo is fubared (which shows real quick in Prime), I'm betting on those two.
Still no go?
Take a separate HD do a complete system reinstall of windows with drivers only and try to stress each component , if there's no freeze than, then your OS is to blame.
Good Luck!
I suspect the memory is the problem, it did fail a memory test.
I use Stress Prime 2004 set to stress the memory for a few hours.
Give it a try, if it fails you do have a memory problem.
