AMD64 OCing and memory voltage....
Clindst
When raising the mem voltage....does that ONLY help with OCing the ram or would it help with OCing the CPU as well. Because as of right now my RAM is not limiting my OC at all so I have no need to raise the RAM voltage but I think i remember someone saying it helps give more power to the memory controller on the CPU itself....
Because right now I am stuck at 2.47 from 2.0 and I am positive my Ram is not limiting my OC...its the CPU...But if I raise the RAM voltage will it help my CPU OC more?
i have heard that it helps in some cases either with the memcontroller on the cpu or the NB which both could be limiting the oc. try it and see.
