I've recently been experimenting with RM Clock and one of my desktops (AMD64 3400+ S754 Newcastle CG-stepping). When I undervolted my CPU initially (also adjusting the multiplier), everything went fine...the clock speed dropped along with the temperatures as expected.
But when I decided to adjust it back to normal settings (stock voltage w/ stock multiplier) the system crashed (froze). After rebooting, I decided to keep the voltage much closer to its default and adjust the multiplier, but after attempting to adjust the multiplier back to stock speeds (with stock voltage), the system crashed once again.
After rebooting again, I decided to investigate further and found that even without a voltage adjustment (only a decrease in the multiplier) the system would still crash. So at the moment, I am unable to underclock/undervolt as I had done the first time.
Was there damage done to the CPU?
Everything seems to be running fine after a reboot.
