AMD64 2800+ HSF choices
DarkLegacy
Will be for my AMD64 2800+ when i get it, plan to OC it so wonder which of the 2 is the better HSF & has easier installation.
http://www.newegg.com/app/ViewProductDesc.asp?description=35-106-038&depa=1
Thermaltake Venus 12
http://www.newegg.com/app/ViewProductDesc.asp?description=35-106-036&depa=1
Thermaltake Silentboost.
Any other options are always a welcome =).
The motherboard will be either the DFI Lanparty UT Nf3, & the MSi Neo 2 plat (Socket 754).Havnt purchased neither yet. Thought I would make ya aware since I know some mobos have issues with certain HSF's.
-DarkLegacy
ok it sounds like you want silent cooling so here my recommendations
the XP-120(for the dfi board,msi wont fit it)
http://www.newegg.com/app/ViewProductDesc.asp?description=35-109-118&depa=0
a fan for this sink is up to you it fits 120mm so thats your best option for silence and good airflow
now the XP-90 fits both boards
http://www.newegg.com/app/ViewProductDesc.asp?description=35-109-119&depa=0
you also can pick a fan to your tastes but this one only fits 92mm fans
edit: actually how much noise will you tolerate, if you dont care heres what i recommend
92mm vantec tornado-119cfm for XP-90
http://www.newegg.com/app/ViewProductDesc.asp?description=11-999-613&depa=0
120mm ystech only 109cfm but will be quieter
http://www.frozencpu.com/fan-22.html?id=LCNAJXru
I have the silentboost... nice hsf.. but i would just get the thermalright xp-120.. but if it don't fit into your mobo.. thermalright xp-90
